Activity › Forums › Adobe Premiere Pro › Nested sequence has visual effects applied twice
  • Nested sequence has visual effects applied twice
    Posted by Amy Young on January 24, 2019 at 6:29 pm
    Yes, I know nesting is evil. I think Premiere Pro has been gaslighting me.
    I have a different nesting problem with effects — they are applied twice it seems. Specifically, the Lumetri adjustment in the container sequence now looks blown out. But if I drag the edited clump directly into the container sequence, it looks as expected. You can see the nested one in white/red, and the edited clump to the left. I’m using an old version of Premiere Pro as I have too many moving parts to update now, and I’m not convinced the problem/bug is fixed, anyway.
    I thought it might be caused when the Lumetri Effect was applied to the master, not the instance. But I tested that, and no change.
    Any suggestions are welcome! Other than “nesting stinks, why bother?” ????
    Amy Young replied 7 years, 8 months ago 2 Members · 2 Replies
  • Blaise Douros
    January 24, 2019 at 7:11 pm
    Check to make sure that Lumetri isn’t applied both to the individual original clip in the nested sequence, and to the nested sequence in the main timeline.
  • Amy Young
    January 24, 2019 at 7:22 pm
    Hi Blaise,
    Yes, I checked that there are no effects applied to the nested piece in the container sequence. Thanks!
