Activity Forums Adobe Premiere Pro Nested sequence ??
  • Nested sequence ??
    Posted by Terry Gipson on March 20, 2008 at 2:27 pm
    I’m thinking of moving to Premiere Pro from another NLE that does not have nested sequences. My questions are:
    1. if I have sequence 2 nested in sequence 1 and then modify sequence 2, is it automatically updated in sequence 1?
    2. and if it is updated, is it updated in sequence 1 in overwrite or insert mode?
    Terry Gipson replied 18 years, 5 months ago 2 Members · 2 Replies
  • Vincent Rosati
    March 21, 2008 at 4:42 pm
    Nested sequences are automatically updated in the nest. However, if the change you make in the nested sequence results in a different runtime (longer or shorter), you would need to correct the I/O point on the nested timeline within the nest timeline.
    1 – Sequence 1 (nest) is updated when Sequence 2 (nested) is changed.
    2 – Unsure
    Vince
  • Terry Gipson
    March 21, 2008 at 6:01 pm
    Thanks. I’ll play around and see.
