Activity Forums VEGAS Pro Nested project
  • Nested project
    Posted by Guillaume Jeffrey on October 19, 2010 at 1:42 am
    I made a wall image using vegas pro 9e by using 9 tracks as i have 9 pictures.
    This wall image is inside a project. I want to add a transition for the whole wall image at the end but I can’t as I have 9 tracks.
    So I think I need to use nested project. However I’m wondering if it’s possible to create a nested project from a timeline selection (similar to pre comp for after effects) as I don’t want to make a again this wall image in a new project (it’s very time consuming).
    Rgds
    Theo Van laar replied 15 years, 10 months ago 3 Members · 4 Replies
  • Aleksey Tarasov
    October 19, 2010 at 3:58 am
    Save the project under a new name. Open it and delete all, except your video wall. Done.
    you can use tools such as https://vegasaur.com/pan-crop-assistant that allows you to create video walls in seconds
  • Theo Van laar
    October 20, 2010 at 9:09 am
    There is also a free tool to create videowalls: davitools
    https://www.davitools.com/default.aspx
    Theo
  • Guillaume Jeffrey
    October 20, 2010 at 9:05 pm
    Hi theo,
    Thanks for yr link. It saves me a lot of time.
    But when I insert a nested project with image I notice that vegas only render on 1 thread(out of 8).
    Have you, guys, experience such behavior?
    Rgds
    Guillaume
  • Theo Van laar
    October 20, 2010 at 11:42 pm
    Vegas is a mutithread application, but not all plugins are. So maybe you used a plugin that does not allow multithread rendering.
    Theo
