Activity › Forums › Adobe After Effects › Nested Particles in Particular?
  • Nested Particles in Particular?
    Posted by Greg Neumayer on November 21, 2013 at 1:10 am
    I’d like to run an instance of particular with the particles being set to randomly using 1 frame from a 5 frame comp. No problem there.
    However, I’d like each of those frames to be a comp that has animation in it’s timeline. Can I do this? It seems like particular makes them freeze-frames and doesn’t let the sub-comps animate.
    My workaround is to have 5 instances of particular on 5 layers, but then I run into conflicts with things in 3D space.
    Thanks for any info,
    Greg
    Antifreeze Design
    https://www.antifreezedesign.com
    Greg Neumayer replied 12 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
