nested compositions – do not crop? how?
i’m trying to create a 3d environment.
floor will have footprints that appear from off screen and continue into the horizon.now here is my question.
my footsteps start way below the boundaries of the composition and continue beyond the upper edge of the composition in order to follow the footsteps with a camera-move in 3d space.
well here is the problem
when i nest the composition with the footsteps, it only shows the steps once they appear within the composition borders (nested compositions are cropped to dimensions set in composition settings). how do i turn the cropping off? so that i can see the entire content of the composition no limited to the boundaries of the composition.
do you understand my quesion? if not, i’d be happy to clarify.
