Activity Forums Sony Cameras NeoScene wont covert audio from Sony NX5U
  • NeoScene wont covert audio from Sony NX5U
    Posted by John Lenihan on April 11, 2010 at 6:06 pm
    I recenty bought a pair of Sony NX5U cameras and did a shoot in AVCHD.
    I Have been having a terribly slow time editing in Vegas 9.0C with Quad Core Pentium.
    Reading this forum, the collective suggestion was to try Cineform Neoscene.
    I downloaded the 7 day trial yesterday, and it converts nicely, but with no audio.
    When I check the log in NeoScene, it says that no audio was detected.
    The audio on these cameras is linear PCM.
    I retried this a dozen times, playing with the few neoscene settings, but no difference.
    I can drag the AVCHD files right into vegas, and it sees the audio, its just slow to preview.
    Andy ideas?
    John Lenihan
    LeniCam Video Productions
    https://www.lenicam.com
    John Lenihan
    John Lenihan replied 16 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    April 11, 2010 at 7:08 pm
    Does NeoScene support NXCAM? Possibly not since it brand new. I would contact Cineform and see what they say.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Lenihan
    April 11, 2010 at 8:18 pm
    Might you have a short clip of avchd that I can download and try. I want to make sure it is not operator error.
    John
    John Lenihan
  • John Lenihan
    April 25, 2010 at 5:13 am
    OK John,
    I have been working with a great tech support at Cineform.
    I sent him a sample clip, they replicated the problem, and sent me several step procedure to fix it.
    Now, I am trying to start with a 3 hour continuous shoot composed of a dozen small files that I would like to both concatenate and convert with Neoscene.
    The tech said Neoscene can not concatenate, but I could use Sony Vegas to point to the Neoscene encoder, and both convert and concatenate. He did not know how to do that however, do you?
    John Lenihan
    John Lenihan
  • Scott Gifford
    July 8, 2010 at 11:03 pm
    Trying to convert AVCHD files from my NXCAM with Neo Scene, video converts however audio does not convert. After reading this thread and others, has anyone discovered a fix?
    Scott Gifford
    Scott Gifford Studios
  • John Lenihan
    July 8, 2010 at 11:19 pm
    Scott,
    Call the cineform support desk. He was very helpful for me, and it was while I was still using a trial version. ( Which I did purchase once it worked).
    That is what I did, and the tech walked me through a bunch of settings to finally get it to work. I can’t remember what I did. I didn’t write it down, I just followed his instructions.
    It had something to do with the codec registering properly with windows in the windows registry.
    John
    John Lenihan
  • Scott Gifford
    July 9, 2010 at 10:05 pm
    Here’s the FIX! This is from Jake at Cineform:
    Here’s what you need to do.
    Browse to the following folder:
    C:\Program Files\CineForm\NeoScene\
    or if you are running a 64-bit OS:
    C:\Program Files (x86)\CineForm\NeoScene\
    Then double click on the file called, ;mc_dec_mpa_ds.ax’.
    If windows asks you how to open the file, browse to:
    C:\Windows\System32\
    and select ‘regsvr32.exe’
    You should get a message saying that the file successfully registered.
    Then try converting again and you should have audio.
    Scott Gifford
  • John Lenihan
    July 10, 2010 at 2:29 pm
    Scott,
    Thank you for taking the time to write down and post the instructions for all of us!
    John Lenihan
    John Lenihan
