Activity Forums VEGAS Pro Neoscene and Vegas Question
  • John Rofrano
    September 10, 2011 at 5:58 pm
    [James Dubendorf] “When I deinterlace the Canon PF 30 footage through neoscene, Vegas does not recognize the resulting AVI as progressive- it does, however, recognize some footage from a Go Pro camera as progressive without a problem. If neoscene is indeed able to deinterlace PF 30 footage, shouldn’t Vegas see this? Any ideas on how to diagnose where I’m going wrong?”
    If you are using the Deinterlace option then this is a question for CineForm. I don’t believe you are doing anything wrong. Perhaps NeoScene has a bug in it? I don’t shoot progressive so I can’t test this.
    [James Dubendorf] “if editing both 60i and 30p footage within the same project, is it preferable to set project properties and render settings to 60i or 30p (knowing one or the other will clash)? “
    If your target is 30p I would set your project up as 30p.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
Page 2 of 2
