Activity Forums Adobe After Effects Need Workflow Advice Premiere -> AE
  • Need Workflow Advice Premiere -> AE
    Posted by Tom Ohmit on September 9, 2011 at 2:43 pm
    Hi all,
    I am currently trailing CS5.5 and planning on switching from FCP to Adobe. So far, I have found it pretty intuitive but very inefficient. It’s probably just a workflow problem, so I’m hoping someone can point me in the right direction.
    The project I am trailing with is a live performance media track for a singer to sing along with and have the video background w/ lyrics on screen for the audience to read. All of the footage is from stock websites. It required that lyrics and transitions be synced up precisely with the rhythm and key points in the song.
    I assembled all of the footage w/ audio in Premiere – piece of cake. I added the lyrics in Premiere, but discovered that Premiere really doesn’t have many transitions and effects options. Not a problem, I imported into AE, but then discovered that the lyrics I created and aligned on the timeline in Premiere just show up as solid blocks in AE.
    So, now I am recreating the lyrics in AE on top of my exported video from Premiere. The problem is, I cannot preview the composition to line up the lyrics I am creating with the audio without doing a RAM Preview. Doing a RAM Preview of 45 seconds of the song (just the chorus) takes about 15 minutes. Then I need to make an adjustment, but it takes another 15 minutes before I can see what I did previewed with audio.
    So, I’ve realized that this isn’t going to work, but I’m not sure what to do? How can I preview my composition with audio without waiting forever for a RAM preview? Is there a way I can scrub with audio at least?
    Any other suggestions would also be greatly appreciated. Thanks!
    Tom Ohmit replied 14 years, 11 months ago 61,966 Members · 2 Replies
  • Tom Ohmit
    September 10, 2011 at 4:22 pm
    Thank you, that does help some. By scrubbing with audio I can at least get lyrics lined up properly. But, there are still many effects I need to sync up rhythmically with the song – things that need to occur precisely on a drum beat, that scrubbing doesn’t provide a solution for – it really needs to be previewed in real-time.
    Is there any way around a RAM preview that would allow for that?
  • Tom Ohmit
    September 11, 2011 at 2:37 am
    ah, ok. that’s the kind of trick i was looking for. thanks for the tip.
