Activity › Forums › Apple Final Cut Pro › Need to use pieces of several projects into another project
  • Need to use pieces of several projects into another project
    Posted by Brian Kruger on August 9, 2011 at 8:37 pm
    I have seven projects in my projects library. I am now doing an eighth project that uses many of the pieces of the previous seven. I’d like to be able to take pieces of of the seven existing projects, and move them into my Events library so I can use them easily. I don’t think I can. Is the only way to do this, is export the projects as QT files and re-import them into the FCP X Event file? I was hoping there was some cool way to select what I wanted from the project, and them move it back up as a usable clip in the Event library. No?
    Brian Kruger replied 15 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • John Pale
    August 9, 2011 at 8:45 pm
    Compound clips are your friend.
  • Brian Kruger
    August 9, 2011 at 8:46 pm
    But how?
    Brian Kruger
    Stunt3 Multimedia
    Grosse Pointe, MI
  • Tom Wolsky
    August 9, 2011 at 10:15 pm
    Select the section you want to use. Opt-G to make a compound clip. Select the CC and copy it. Paste into a new project. Repeat. Rearrange. Re-edit.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Brian Kruger
    August 9, 2011 at 10:16 pm
    Thanks Tom, you’re the best!
    Brian Kruger
    Stunt3 Multimedia
    Grosse Pointe, MI
  • John Pale
    August 9, 2011 at 11:12 pm
    Tom is definitely one of the best.
    I would have given you more detail but I tend to write shorter posts when using my iPhone.
    But if you typed “Compound Clip” into the FCPX Help you would have gotten everything you need to know.
  • Andy Neil
    August 10, 2011 at 4:05 pm
    Nice tip Tom. I only wish they made it more intuitive like allowing you to create compound clips from the project into an event or even allowing drag and drop of compound clips into events. Add it to the list I suppose.
    Andy
    https://www.timesavertutorials.com
  • Brian Kruger
    August 10, 2011 at 4:13 pm
    Exactly, Andy. After making some complex modifications to several clips in the project line, it would be great to make a compound clip and drag that up into the events library for use later.
    Brian Kruger
    Stunt3 Multimedia
    Grosse Pointe, MI
