Activity Forums Apple Final Cut Pro Legacy need to upgrade graphics card
  • need to upgrade graphics card
    Posted by Enrique Aguirre on January 16, 2012 at 7:33 pm
    here’s what i’ve got:
    Model Name: Mac Pro
    Model Identifier: MacPro2,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 3 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 8 MB
    Memory: 8 GB
    Bus Speed: 1.33 GHz
    Boot ROM Version: MP21.007F.B08
    SMC Version (system): 1.15f3
    Chipset Model: ATY,RadeonX1900
    Type: Display
    Bus: PCIe
    Slot: Slot-1
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: ATI (0x1002)
    Device ID: 0x7249
    Revision ID: 0x0000
    ROM Revision: 113-A52027-202
    EFI Driver Version: 01.00.202
    i’m having problems with doing rough comps w/prores 4444 footage. can’t even do an opacity change to line up 2 layers. maybe not enough graphics card horsepower? my box has got another 12 mos life in it as a cutting station. what’s the smart play upgrading the card?
    thanks.
    Enrique Aguirre replied 14 years, 7 months ago 2 Members · 2 Replies
  • Neil Patience
    January 16, 2012 at 8:18 pm
    Dave beat me to it while I was replying but basically same question . . . .
    There are some options with the video card on your machine – here is what Apple list as compatible
    https://support.apple.com/kb/ht2848
    You may find a faster graphic card helps but there are other potential bottlenecks. Whilst the faster cards in that list might offer some gain I am not sure they are going to add huge performance to straight video playback alone.
    You dont say what kind of hard drives you are using.
    ProRes 4444 are very large files and require fast drives to play smoothly especially more than one stream.
    Just out of curiosity what kind of work are you doing with the 4444 files.
    What is your storage set-up ? I wonder if that is possibly slowing you down.
    best wishes
    Neil
    http://www.patience.tv
  • Enrique Aguirre
    January 16, 2012 at 8:21 pm
    xsan via fibre. playback’s not the prob. it’s trying to crop, set opacity between 2 layers, etc.
