Activity › Forums › Apple Final Cut Pro Legacy › Need to understand something regarding audio
  • Need to understand something regarding audio
    Posted by Martin Touhey on August 1, 2013 at 1:25 am
    My producer and I are having a bit of a problem. We’re editing a trailer and we’ve made some audio edits to a stereo music track that had to be extended. We extended the track and after a late night we agreed that it sounded fine. When I returned home I noticed that the music was off by about a beat or 2, so I decided to take the original audio file and extend the track with an external audio program. I re-inserted the audio file into the FCP project file onto a new audio layer and adjusted my edits to fit the new music. I alerted my producer to the change and he was upset that I had used an external audio program to edit the music. He claims that it is a workflow issue. I’m unaware of any issue that could arise from changing the audio other than minor edits to the video. Can somebody explain what my producer is talking about?
    Inside the Dragon’s Lair
    http://www.vimeo.com/37600315
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Martin Touhey replied 13 years, 2 months ago 2 Members · 2 Replies
  • Steve Eisen
    August 1, 2013 at 2:46 am
    Each person has their own opinion. I would have kept my mouth shut and if see if the producer noticed the change.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Martin Touhey
    August 1, 2013 at 12:32 pm
    Thanks for the response. He would definitely notice the change as it would be reflected in the timeline. I think his issue might be that we are using 2 different hard drives with the same information on both. This way we can make edits independently and just trade FCP files over email. Once I change the actual audio file, his hard drive doesn’t reflect the change until we get together and update his drive with the new file. If the edits we’re made in final cut only then we could just transfer the FCP project file and not worry about reconnecting the media. The larger audio file would take longer to upload to a dropbox and also to download on his end. Also he’d have to place the audio file in the same place as it’s mapped on my drive to avoid reconnection errors. I’m not sure if this is his issue 100%, but I think it’s close to what his complaint about workflow is.
