Activity › Forums › Adobe After Effects › Need to spin a drawing of a sun without moving it’s placement in the comp.
Posted by Stan Mendoza on April 27, 2012 at 9:33 pmI understand how to use 3D and basic 3D but how do I spin the drawing without it moving its postion?
Stan Mendoza replied 14 years, 4 months ago 3 Members · 3 Replies -
John Cuevas
April 27, 2012 at 9:37 pmYou need to use the Pan(P) behind tool to move your anchor point to the center of the object you would like to rotate in 3d.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Dan Fredley
April 27, 2012 at 11:02 pmIf you already have position keyframes for the drawing then moving the anchor point will mess up your animation. You could place a 3D null object in the center of your layer, then parent the layer to the null, then rotate the null.
One way to place the null at the exact layer’s position at the exact time you want it to spin is to create the null, make it 3d, drag the null’s parent pick whip to the sun layer. Type 0 (zero) in all position, rotation, orientation values of the null, then unparent it. Select “Local Axis mode” then drag the x and y axes to the center of your layer. If the anchor point z position of your layer is not 0 for some reason, then you’ll have to take the negative value of the z coordinate to zero that out. Then parent the layer to the null and keyframe the null rotation values. This makes it better than just guessing where your layer is in 3D.
Kind of convoluted, but I use this process all the time.
Dan Fredley
Stan Mendoza
April 28, 2012 at 7:22 pmJohn
Thanks for your help. It worked, I can spin the sun all day:)
Stan
