Activity › Forums › Apple Final Cut Pro Legacy › need to see pal fcp work on television
Posted by Carl Kesser on June 13, 2005 at 1:21 pmI need to find out how to see pal project on tv. What card do I need to export from my computer to monitor? I’d like not to spend much money since I need to do this infrequently.
Matt Sandström replied 21 years, 3 months ago 5 Members · 7 Replies -
Matt Sandström
June 13, 2005 at 1:27 pmis it dv? if so a firewire dv converter like the dazzle hollywood dv bridge is what you need. useful even for ntsc work when you need to use your deck or camera for something else. and you need a pal monitor too of course, but i assume you can easily rent those.
/matt
Kaspar Kallas
June 13, 2005 at 3:06 pmIf you work with uncomprssed timline then balckmagic design has decklink cards wich are rather inexpensive
-Kaspar
Shane Ross
June 13, 2005 at 5:37 pmOr simply firewire out to your camera, then RCA (or s-video) from the camera to the TV. No additional equipment needed. And no wear and tear on the camera either.
Dazzle? Avoid the Dazzle. If you want a dedicated converter, get the ADVC-100 by Canopus. That is the gold standard of DV converters, and it is cheap. $265.
But as I said, no additional hardware is needed. Just your camera as the piece of equipment between your computer and TV.
Carl Kesser
June 13, 2005 at 6:28 pm[Shane Ross] ”
Return to Posts Index Read Entire Thread Reply To This Post
Note: To include any portion of this post in your response, highlight the desired text with your mouse and hit the “Q” key.Name: Shane Ross
Date: Jun 13, 2005 at 1:37 pm
Subject:?? Re: need to see pal fcp work on television
Or simply firewire out to your camera, then RCA (or s-video) from the camera to the TV. No additional equipment needed. And no wear and tear on the camera either.Dazzle? Avoid the Dazzle. If you want a dedicated converter, get the ADVC-100 by Canopus. That is the gold standard of DV converters, and it is cheap. $265.
But as I said, no additional hardware is needed. Just your camera as the piece of equipment between your computer and T”
Thanks for your response. I am in the states and do not have a pal camera here to go from computer to camera to tv. Is canopus a card to put into computer with s-video out to tv/pal.
thanks
Carl -
Carl Kesser
June 13, 2005 at 6:35 pmThanks for your help. I don’t have a pal camera in the states. Is there a card to put into my computer out to pal tv.
Carl Kesser -
Mitchji
June 13, 2005 at 6:53 pmHi,
Connect the Canopus ADVC-110 via FW to your Mac and connect a Monitor or TV that plays PAL to the Canopus via Y/C or (cringe) composite.
https://www.canopus.us/US/products/ADVC110/pm_advc110.asp
Its compatible with both NTSC and PAL:
https://www.canopus.us/US/products/ADVC_selection_guide/pm_advc_selection.asp -
Matt Sandström
June 13, 2005 at 11:38 pm[Shane Ross] “Or simply firewire out to your camera, then RCA (or s-video) from the camera to the TV.
don’t you need a pal camera for that? i have a pal camera and it doesn’t output ntsc.
Dazzle? Avoid the Dazzle.”
i said “like” the dazzle, and you’re probably right. i’ve used one and it worked, plus it’s cheap, that’s all.
/matt
