Activity Forums Adobe After Effects need to replace AVI and retain cloning/ tracking data- how to do?
  • need to replace AVI and retain cloning/ tracking data- how to do?
    Posted by Jon Iverson on July 7, 2010 at 3:45 am
    How can I transfer the tracking and cloning data from one AVI to another? In other words, I have two nearly identical AVIs except one has more color saturation than the other. However, I only tracked and cloned within the video of less saturation. Now I need to transfer this data to the identical video with more color saturation. What would even be better is if I could somehow drag the video with more saturation directly on top of the first and all effects would then apply to the replacement, however when I try moving the videos they just want to go above or below the one I’m trying to replace.
    Jon
    Jon Iverson replied 16 years, 1 month ago 2 Members · 2 Replies
  • Joseph Pole
    July 7, 2010 at 4:19 am
    Jon
    On the timeline…
    Duplicate the layer with the tracking data effects etc(the less saturated one in your case)
    Highlight the duplicated layer
    Then go to the project window
    Select the footage item you want to add effects to (the more saturated one in your case)
    Hold down the alt key and drag the footage from the project window to the timeline.
    that should do it
    j
    http://www.josephpole.com
  • Jon Iverson
    July 7, 2010 at 3:03 pm
    Joe,
    Thanks a lot! This worked well and saved me from perhaps tons of extra work trying to figure out what to do.
    Jon
