Activity Forums Apple Final Cut Pro Legacy Need to open an FCP 6 file in FCP 5
  • Need to open an FCP 6 file in FCP 5
    Posted by Mike Throck on January 11, 2010 at 8:30 pm
    I know I can’t just open an FCP 6 file in FCP 5, but is there any sort of XML export I can import into FCP 5?
    I don’t have any special transitions or plugins being used in the project.
    Mike Throck replied 16 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 11, 2010 at 8:57 pm
    Just export an XML from FCP 6, version 3 if you are going to 5.1, or version 2 if you are going to FCP 5.0.
    #46 – Supported XML versions
    Shane’s Stock Answer #46 – Final Cut Pro and versions of XML it supports
    FCP4 supports XML version 1 only
    FCP5 supports XML versions 1 and 2
    FCP5.1 supports XML versions 1, 2 and 3
    FCP6 supports XML versions 1, 2, 3 and 4
    FCP7 supports XML versions 1, 2, 3, 4 and 5.
    Shane
  • Mike Throck
    January 11, 2010 at 11:10 pm
    Awesome, thank you.
