Activity Forums Adobe After Effects Expressions Need to modify a marker-based expression
  • Need to modify a marker-based expression
    Posted by Lauren Roundy on September 4, 2019 at 10:41 pm
    I have a small animation happening in a precomp. Then, when that precomp is nested into the main comp, I have the following expression applied to Time Remap.
    I would like to adjust the expression so that I don’t have to type a comment in the marker comment section. In other words, I want it to do what it is currently doing with the markers but without having to type a comment for every marker.
    I just want it to play the same animation every time I have a marker (except for the first marker).
    // Marker Sync Expression
    // Modified expression based on Dan Ebbert's Marker Sync Expression
    // Original Version: https://www.motionscript.com/design-guide/marker-sync.html
    src = comp("Death_icon").layer("Markers");
    n = 0;
    if (marker.numKeys > 0) {
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time) {
    n--;
    if (n == 0) {
    0
    } else {
    m = marker.key(n);
    myComment = m.comment;
    t = time - m.time;
    try {
    mark = src.marker.key(myComment);
    if (src.marker.numKeys > mark.index) {
    tMax = src.marker.key(mark.index + 1).time - mark.time;
    } else {
    tMax = src.outPoint - mark.time;
    t = Math.min(t, tMax);
    mark.time + t;
    }catch (err) {
    0
    Lauren Roundy replied 7 years ago 1 Member · 1 Reply
