Activity › Forums › Adobe After Effects › Need to export a .tga sequence
  • Need to export a .tga sequence
    Posted by Sam Lesante jr. on September 7, 2007 at 8:05 pm
    This is my first time in this forum.
    I have about 30 minutes of knowledge on AE.
    So with that said, can anyone help me make 2 .mov’s into a .tga sequence?
    The first .mov is the actual animation and the second is obviously the matte.
    I don’t know how to combine them into one file then export them into the .tga sequence.
    TIA
    Sam
    Kevin Camp replied 19 years ago 2 Members · 1 Reply
  • Kevin Camp
    September 7, 2007 at 9:04 pm
    bring them both into after effects. then select them both and drag them on the new comp button (film strip looking button at the bottom of the project window). choose single comp, no other options. in the timeline window, place the matte footage above the fill.
    from the timeline, if needed bring up modes… there are a few ways to do this, one is from the little arrow in the upper right corner of the timeline, click and choose columns>modes. then, for the fill layer, from the trkmat pulldown in the maods panel choose luma matte from layer above.
    that will apply the matte to the fill. now you can choose composition>make movie and click the output module, hwere it says lossless. from the top pulldown, where it says format, select targa sequence. then set the video output to rgb+alpha and millions+.
    that’s the basics…
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
