Activity Forums VEGAS Pro Need to export a 1998×1080 24fps file from Final Cut Pro
  • Need to export a 1998×1080 24fps file from Final Cut Pro
    Posted by Catherine Pirotta on January 29, 2010 at 11:35 pm
    I have a movie (110min long) in FCP 1080×720 23.98fps.
    How can I export it to be 1998×1080 24fps so I can take it to create a JPEG2000 later?
    Which settings should I use when I export?
    Can I do it Using Quicktime conversion? And if I use the compressor? Should I use HD uncompressed what bit?
    Please HELP
    John Rofrano replied 16 years, 7 months ago 3 Members · 3 Replies
  • Bob Peterson
    January 30, 2010 at 12:11 am
    Are you asking how to export from FCP?
  • Catherine Pirotta
    January 30, 2010 at 5:01 am
    Yes, I want to know which setting? HD uncompresed 8 bit? HD uncompressed 10bit? HPX HDV ????? so many different ones.
    I tried using the compressor and selected HD uncompressed 10bit and just changed the fram size from 1920×1080 to 1988×1080 and the fps from 23.98 to 24fps.
    The only thing is a 2min sample went from 666MB to 15GB, what’s gonna happen when I try my whole movie which is 36GB?
    May be there’s another way to export it, with another settings. I know someone guided me last time and it was using fianl cut conversion, not through the compressor.
    The result clip simply needs to be 1988×1080 and 24fps.
  • John Rofrano
    February 1, 2010 at 5:20 pm
    You might get more responses if you post this in the Apple Final Cut Pro Forum here at the Cow. This is the Sony Vegas Forum.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
