Activity Forums Adobe After Effects Need to convert Shape Layer to outlines?
  • Need to convert Shape Layer to outlines?
    Posted by Israel Long on September 11, 2012 at 6:32 pm
    Anyone know if this is possible?
    Maybe a script?
    I need to convert a few Shape Layers to outlines/masks for use in Element3D.
    I created the Shape Layers in the normal fashion:
    -drew a random closed bezier path on a shape layer
    -used the shape layer tools to make it far more complex & cool
    Now I would like to convert this new shape to outlines or a mask.
    (Similar to Illustrator’s “Object > Expand” function)
    Any help appreciated:)
    Israel “Izzy” Long
    Motion and Title Animation
    ragecg.com
    Israel Long replied 14 years ago 2 Members · 3 Replies
  • Tom Daigon
    September 11, 2012 at 6:54 pm
    Heres a shot, how about using Autotrace on the shape layer to create a mask?
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Israel Long
    September 11, 2012 at 8:29 pm
    Thanks Tom & Dave, very much:)
    And please lemme know if I’m doing any of this incorrectly:)
    Tom: Sadly, I tried Autotrace, and as it derives it’s result from the rasterized rgba information of a layer, much like Illustrator does, the result is not as clean as I need:(
    Dave: Sadly, since a shape layer is Parametric and not Bezier, there is apparently no copyable path property… unless I missed it?
    Please let me know if I did:)
    See image:
    Thanks again.
    Israel “Izzy” Long
    ragecg.com
  • Israel Long
    September 11, 2012 at 9:29 pm
    Because if you look at the image I attached to the last post, once you adjust the parameters of the shape layer options, the shape becomes far more complex than a simple primitive shape, etc.
    For example, you can draw a single simple ellipse, then adjust it to look like a ring of random, offset dash shapes of different sizes and legths etc., like this:
    So, sadly, there is no “expanded” information to copy-paste:(
    However, please keep those ideas coming:)
    Israel “Izzy” Long
    ragecg.com
