Activity › Forums › VEGAS Pro › Need to convert completed Blu-Ray to Standard
  • Need to convert completed Blu-Ray to Standard
    Posted by Jeff Mcguire on December 10, 2009 at 2:19 pm
    Hey all
    Just completed a 1:45:00 Blu-Ray disc for a bride. She has requested a standard dvd version now. What is the quickest method to do this using DVD Architect 5.0 and/or Sony Vegas Pro 8.1?
    Jeff
    Jeff Mcguire replied 16 years, 9 months ago 2 Members · 6 Replies
  • John Rofrano
    December 11, 2009 at 2:04 pm
    Change your DVD Architect project from Blu-ray to standard def widescreen DVD in the properties and burn again. It should convert the HD into SD and re-author the disc in the appropriate DVD format.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeff Mcguire
    December 11, 2009 at 2:25 pm
    Will the program automatically make it fit a 4.7Gb dvd?
    Jeff
  • John Rofrano
    December 11, 2009 at 3:10 pm
    Yes, it will use whatever bit-rate necessary to make it fit.
    ~jr
  • Jeff Mcguire
    December 11, 2009 at 4:18 pm
    Thanks! I’m trying it now. Looks like I had to press the Fit to Disc button after changing to DVD in Properties.
    For some reason I thought I had to re-render in Vegas.
    Jeff
  • John Rofrano
    December 11, 2009 at 6:35 pm
    Well… you could re-render in Vegas but DVD Architect is just as capable. It’s also quicker because Vegas would have to re-render all of the FX, etc. while DVD Architect can take advantage of the fact that you have a perfectly good high quality 25MBps HD file to render from.
    ~jr
  • Jeff Mcguire
    December 11, 2009 at 6:39 pm
    Makes perfect sense. Thanks!
    Jeff
