Activity Forums Adobe Premiere Pro Need to convert 23.976 to 24 for DCP creation
  • Need to convert 23.976 to 24 for DCP creation
    Posted by Greg Popp on November 12, 2013 at 3:50 pm
    I have a 23.976 sequence (built from DPX files exported from SpeedGrade and also with title clips) within Premiere Pro CC.
    I want to export the sequence at 24fps and I’m not sure how to do that best. I’m not concerned about audio (I already have stems from a sound designer that have been converted in Pro Tools to 24fps).
    I have a ProRes 422 master file that I suppose I could import back into Premiere, modify the frame rate with “Interpret Footage”, and then add to a 24fps timeline and re-export. But that involves an extra generation.
    I can’t just export the 23.976 sequence and set the frame rate to 24, can I?
    Any thoughts on the best way to do this to preserve quality? Thank you.
    Greg Popp replied 12 years, 9 months ago 2 Members · 2 Replies
  • Chris Gunningham
    November 13, 2013 at 10:21 pm
    I would copy all your clips from your 23.98 timeline into a 24fps timeline. Check timings and export as 24 Fps, hopefully that will work.
    Chris Gunningham
    Online/VFX Editor
    Any opinions expressed are solely my own.
  • Greg Popp
    November 13, 2013 at 10:34 pm
    Thanks Chris. My concern is not having “interpolated” the footage first. I’ll guess I’ll find out!
