Activity Forums Zaxwerks Need to change output size
  • Need to change output size
    Posted by Dm Floyd on September 26, 2006 at 5:19 pm
    Just rendered my first 3D text animation (rendered quicktime movie as animation millions colors+) and imported into fcp 5, only problem is the animation is not 720×486 it is smaller. I need to blow it up by 15% to fit to edge safe and that degrades the quality of the text. How can I increase the
    scene size in zaxwerks.
    Thanks for the help…program is cool.
    DM
    Jon Okerstrom replied 20 years ago 2 Members · 1 Reply
  • Jon Okerstrom
    September 26, 2006 at 10:06 pm
    Hi DM,
    You’re right not to try to resize an animation that’s rendered at the wrong resolution. Better to change the resolution size in ProAnimator or Invigorator/AE and crank out the movie at the correct resolution.
    Click the camera icon below the scene preview window. Choose the resolution preset you want or enter your own numbers and choose the proper pixel aspet ratio then re-render your movie.
    Does this help?
    Jon
