Activity Forums VEGAS Pro Need to brush up on some basics
  • Need to brush up on some basics
    Posted by Morgan Lewis on June 13, 2013 at 1:37 pm
    I haven’t used Vegas in a little while (Pro 10), just a few questions.
    1) How can I speed up or slow down a segment of video? For a fast-forward montage or the like?
    2) How do you make it zoom in on a specific part of the video?
    3) Let’s say I have split a video into three parts using the Split function, two big bits with a small bit in the middle which I don’t want in the video, but want to keep aside for later. If I wanted to render the two big bits, would I absolutely need to move the small bit and join the two big ones? Or is there a simpler way to micromanage parts of videos?
    Thanks 🙂
    Roger Bansemer replied 13 years, 2 months ago 2 Members · 1 Reply
  • Roger Bansemer
    June 13, 2013 at 3:19 pm
    You can use the velocity envelope to speed or slow.
    Right click on your event and go to insert/remove envelope and then velocity. You can change speed within the event with this.
    The other way is to hold down your ctrl key and stetch or reduce the event.
    Pan/crop is how you zoom in. Use the keyframes if you want to zoom in and out during the event.
    Roger Bansemer – PaintingAndTravel.com
