Activity Forums Adobe After Effects Expressions Need to automate – rotate layer A from 0 to 30 then back to 0 while B is rotating 180 deg.
  • Need to automate – rotate layer A from 0 to 30 then back to 0 while B is rotating 180 deg.
    Posted by Sasha Dal ponte on November 19, 2015 at 2:34 pm
    Hello!
    I have two layers – A and B.
    Layer A is linked to null and it is rotated from 0 to 180 deg.
    Layer B is linked to layer A and it needs to rotate in a specific way.
    When layer A rotation value is 0, layer B also needs to be 0.
    When layer A rotation value is 45, layer B needs to be 30.
    When layer A is 180, layer B needs to be back to 0.
    That, of course, needs to be smooth, not in jumps.
    So I need expression that would read layer A rotation value and rotate layer B accordingly.
    Sasha Dal ponte replied 10 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 19, 2015 at 5:52 pm
    Something like this should work:
    r = thisComp.layer("Layer A").transform.rotation;
    if (r < 45){
    linear(r,0,45,0,30);
    }else{
    linear(r,45,180,30,0);
    Dan
  • Sasha Dal ponte
    November 22, 2015 at 9:14 am
    Thanks Dan!
    It works perfectly! I just adjusted 45 angle to 90 because I put it in wrong in original post.
