Activity › Forums › Apple Motion › Need to add a scene on side of vehicle door
Posted by Geri Bastian on November 24, 2015 at 8:24 pmHi, Need some advice on how to create an effect. I’m using Motion 5.2.1 and I have a shot of an expedition and I want to add a scene on the door. What is the best way to create this so it follows all the curves of the vehicle? Any advice is greatly appreciated
GeriDeyson Ortiz replied 10 years, 9 months ago 3 Members · 11 Replies -
Deyson Ortiz
November 24, 2015 at 10:27 pmDo you have a sample of the clip that you can share? This will help us serve you better. 🙂
– Deyson Ortiz – Editor / Motion Graphics
_______________________________________– View my work at: http://www.Deyson.com
– Download Free Motion Master Templates at: http://www.motion-master-templates.com/
– Watch my Apple Motion Podcasts at: https://my.creativecow.net/Deyson-Ortiz/podcasts
Geri Bastian
November 24, 2015 at 11:59 pm -
Deyson Ortiz
November 25, 2015 at 12:04 amIs the shot moving? What is the scene you want to add to the door?
Geri Bastian
November 25, 2015 at 2:05 amyes the shot is a slow dolly and the scene I want to add is a keyed waste up shot of man giving a testimonial
Robin S. kurz
November 25, 2015 at 9:51 amYou could simply use Motion’s corner-pin tracker, but I would personally opt for Coremelt’s TrackX and do it in FCP X where I’m assuming you’re doing the rest anyway, no? TrackX is not only much easier to handle, but the results will be much better more often than not.
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Geri Bastian
November 25, 2015 at 2:52 pmThanks RK, but I’m looking for the video to also follow the indents in the middle of the door as well
Robin S. kurz
November 25, 2015 at 2:56 pm[geri bastian] “to also follow the indents in the middle of the door as well”
Well, you’re not going to find anything IN or FOR Motion for that. Unless a displacement map is enough, which generally isn’t quite as elegant as say, a mesh-warp of sorts, which is what I’m assuming you’re thinking of.
– RK
Geri Bastian
November 25, 2015 at 3:01 pmyes I was looking for a simple mapping concept. I have not tried the displacement map.
Robin S. kurz
November 25, 2015 at 3:03 pm[geri bastian] “I have not tried the displacement map.”
Well, you’d have to MAKE it first. 😉
– RK
