Activity Forums Adobe After Effects need this eps saved so i can open is illustrator cs5.5 it was created in 6
  • Bradley Freedman
    September 18, 2013 at 10:21 am
    got this sorted now…cheaped it
  • John Cuevas
    September 18, 2013 at 11:34 am
    In Illustrator, you can save to a legacy format, after you choose save, and the large save box appears with the options under versions just choose the legacy format. I saved your file as a CS5, didn’t see CS5.5 listed.
    6528_6526northribbonleftlockupcs5.eps.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
