Activity Forums Zaxwerks Need Swatches In Correct Folders!
  • Need Swatches In Correct Folders!
    Posted by Th3rdeye on January 15, 2007 at 5:05 pm
    Hi
    Somehow my swatches for light, lighting style, material and object style swatches for Invigorator Pro 4 are all in one folder under Zaxwerks. I need to know which goes in which swatch folder. As you all may know the file extensions are ZXM, ZXS, ZXS, ZXI, ZXL, etc. Whenever i pull up my styles and materials, everything or nothing is in their like it should be on default. Please help. thanks.
    Jon Okerstrom replied 19 years, 7 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    January 16, 2007 at 1:27 am
    Hi th3rdeye,
    Doing a clean install is the simplest, fastest way to correct this – you can save the old libraries you’ve made and add them to the standard libraries.
    Jon
