Activity Forums Apple Final Cut Pro Legacy Need Suggestion gamma shift color correction
  • Need Suggestion gamma shift color correction
    Posted by Tony Lee on January 31, 2008 at 5:43 pm
    hello everyone after of doing alot of research and reading alot forums can not seem to find the fix for the gamma shift or video getting darker than the oringal source when output to DVD mastering. What i asking is what you guys suggest and been doing for the workaround. I like to hear it and would like to have this post as a good reference for everyone that are still looking for workaround and new to mac editing.
    1.) someone suggest to creat nesting sequence and add a filter gamma correction. ( but how much adjust up or down )
    please add to this post. Thanks in advance to all editors.
    Charlie Chang replied 18 years, 5 months ago 6 Members · 14 Replies
  • 14 Replies
  • Aaron Neitz
    January 31, 2008 at 5:51 pm
    You’re using Encore to create you DVD’s, correct?
    What codec are you editing in?
    Have you tried using iDVD as a test to see if you have gamma shift with that?
    Are you watching these finished DVD’s on a calibrated monitor that’s in line with your broadcast monitor?
  • Tony Lee
    January 31, 2008 at 6:27 pm
    for SD i using dvd studio pro
    for HD i using Encore
    mpeg
    h.264
    not interesting in idvd.
    yes, using AJA Kona LHE with output to broadcast monitor.
    remember my source is great. problem is when mastering to dvd in sd or hd bd.
  • Aaron Neitz
    January 31, 2008 at 6:44 pm
    I’m trying to find out where your gamma problems are happening. That’s why I’m suggesting these things.
    how are you creating your mpeg-2 streams or h.264 streams?
    When you’ve burned this DVD, where are you watching it? Are you watching it on the same television that you’re editing on? Are you watching it on the computer monitor? Are you comparing the mpeg-2 stream on the computer monitor to the burned dvd?
    You should not be having gamma shifts. We just need to find the one small step where things are going blooey.
  • Tom Brooks
    January 31, 2008 at 6:56 pm
    Gamma shifts were a problem with earlier versions of Compressor. Which version are you using?
  • Tony Lee
    January 31, 2008 at 7:02 pm
    – gamma problem when output to dvd mastering dvd studio/ encore.
    – step. editing on fcp – output to quicktime – compression to mpeg2 dvd spec. – import to dvd studio – mastering dvd.
    – apple compression 2.0 for mpeg-2
    – watching on consumer tv or client tv.
    – I’m comparing the dvd with my timeline source and my original source from tape.
    -when i said gamma shifts. the video of the dvd is alittle darker then my timeline video or my original source. correct me if i wrong.
    I thought wrong you see in the timeline of fcp is what you get in the final dvd mastering.?
  • Tony Lee
    January 31, 2008 at 7:05 pm
    I using 2.0 compressor. but if i try to import the quicktime for my fcp to encore it still have same problem. i let encore cs3 transcode my quicktime to mpeg2 stream for dvd.
  • Jeremy Garchow
    January 31, 2008 at 7:31 pm
    You are editing in h264? That could be your problem.
    Also, are you sure that your DVD player isn’t adding setup to the image? Could be a ‘gamma shift’ of sorts but not really, you mentioned in an earlier post that it looked like watching your prgram though a glass of milk which could be setup. What kind of tv do you have and how is it hooked up?
  • Aaron Neitz
    January 31, 2008 at 7:45 pm
    Do this for me:
    Export video to QT on your desktop.
    Use Compressor to create MPEG-2 (.m2v)
    Open original QT in QT player
    Open MPEG-2 file in QT player
    Is the MPEG-2 darker between the 2 Quicktime Player windows?
  • Tony Lee
    January 31, 2008 at 9:16 pm
    Aaron Neitz and to all.
    I will test the mpeg as aaron suggestion for troublshoot. i sure i did in the past many time. but i will do it again to have an accurate post. meantime im out in the field so wont be back until tonight. and yes i will want everyone to continue this post.
    thank
  • Tony Lee
    thank
