Activity › Forums › Adobe After Effects › Need some tips
  • Need some tips
    Posted by Mattijs Bosveld on April 26, 2013 at 9:09 am
    Hi all,
    I’m not an expert in After effects, but I’m trying real hard.:)
    I want to follow a line that is drawn with 3d stroke and I want to follow that line with a camera in a sort of helicopter style (as if a helicopter is following the drawing (I hope this explains it wel… :S)
    What I’ve done till now is draw the line with a pen tool and use the 3d stroke effect.
    Than I parented a camera to a null object and copied the mask path to the position of the null.
    The thing I need to do now is change the perspective of the camera to a helicopter view.
    Is this the right way to do it? Or is there another way?
    Thnx a lot for your help!
    Dale Miles replied 13 years, 5 months ago 2 Members · 1 Reply
  • Dale Miles
    April 26, 2013 at 3:09 pm
    I’m not an expert either, but I was thinking of the same process myself, not ran through it yet, But I wanted a camera to follow a path slightly behind and above, in 3d space.
    The way you have wrote is the exact way I thought in my head to set it up. Then just change the camera target / perspective.
