Activity Forums Maxon Cinema 4D Need Some Suggestions on Motion Tracking or Match moving
  • Need Some Suggestions on Motion Tracking or Match moving
    Posted by Alex Anderson on April 6, 2018 at 8:08 am
    hello everyone.
    i have followed many tuts online and tried C4D motion/camera tracking with mixed results, Some clips will work fine but most of the other will fail to hold object to tracked positions, its always sliding. BUT same clips will work great in After effects.
    So , now need some suggestion to accurately track it and before that below things need clarification
    1. where all i need to set FPS information of the clip in c4d before starting ? , say render seting/project setting should match ??
    2. simple auto track will it work to hold objects in place ??
    3. how to set fractional FPS value in project/render setting like 29.234 [non-standard]
    any good tuts you can suggest ? most of them start just by showing tracking , no information on how to setup project or other setting before start
    Learn..Learn..Learn
    Alex Anderson replied 8 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
