Activity Forums Apple Final Cut Pro Legacy Need smooth slo-mo from Sony Cineframe!
  • Need smooth slo-mo from Sony Cineframe!
    Posted by David42 on August 31, 2006 at 5:58 pm
    Hey, thx in advance, on deadline here.
    I’m looking for a recipe to get smoothe slo-mo from dv footage shot with Sony Cineframe effect. The issue seems to be the simulated 3:2:2:3 pulldown? I don’t have access to AfterFX. Does FCP offer tools to make the motion linear, either before or after slomo?
    Any hot plug ins that work with Cineframe?I’m playing with a Nattress “G Detect Cadence”, but haven’t got a ahndle on the process.
    Sony, are you listening? We want true progressive capture, not in-cam scroz!!
    Arghhh.
    Johnw3d replied 20 years ago 3 Members · 2 Replies
  • Graeme Nattress
    August 31, 2006 at 10:07 pm
    No, they don’t listen. No point even trying to speak to them. For slowmo, you best shoot at the highest frame or field rate possible – so 60i would be best. If you remove the pulldown from your fake 24p you’ll get better results, but you still need twixtor or something with optical flow to get a good slomo, and that’s from a super-slow render….
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Johnw3d
    September 1, 2006 at 10:45 pm
    Apple’s Shake ( https://www.apple.com/shake/ ) will also produce excellent optical-flow based slo-mo, as well as being a generally powerful compositing and image processing tool, now reasonably priced.
    John
    https://www.lyric.com/fcp-plugins/
