Activity › Forums › Apple Final Cut Pro Legacy › Need sequence setting guidance
  • Need sequence setting guidance
    Posted by Roli Rivelino on January 25, 2010 at 4:28 pm
    I record clips on my Panasonic HVX onto my FS-100, my camera is set to video cam and I’m recording at 720p 25 on my FS-100 I’m set to DVCPRO.
    So what I’m wondering is, why my QT compressor settings, inside my sequence settings are set to DVCPRO HD 720p50 and why I see 50 frames in a second instead of 25?
    I know this is really basic stuff, but I wasn’t paying attention earlier!
    Many thanks for your help.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 16 years, 8 months ago 2 Members · 4 Replies
  • Shane Ross
    January 25, 2010 at 5:18 pm
    720p is a 50 frame (or 60 frame in NTSC land) format. Unless you chose 25pN, your footage will be 50 frames per second.
    Shane
  • Roli Rivelino
    January 25, 2010 at 7:55 pm
    aha I see, thanks Shane, is there any advantage/disadvantage using 720p over PN?
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Shane Ross
    January 25, 2010 at 8:17 pm
    [Roli Rivelino] ” is there any advantage/disadvantage using 720p over PN? “
    Saves space. Allows for you to shoot great slow motion at 720p60. And if you deliver DVDs, or masters that are 23.98 than it is great. And having a Capture card that will add the proper pulldown when you output helps with the conversion too.
    Shane
  • Roli Rivelino
    January 25, 2010 at 9:21 pm
    You’ve enlightened me once again, many thanks Shane.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
