Activity › Forums › DVD Authoring › Need Script to Play Track 2
Posted by John Dobovan on April 25, 2012 at 4:31 pmHi:
I have a DVD project with 2 tracks. Track 1 loops until the play button is hit, which then activates Track 2. At the end of Track 2 the project reverts to the Track 1 loop. I’ve got everything working except for a script that causes Track 2 to play when the play button is hit. I’ve set both Title and Menu to play Track 2 but of course there is no preset for Play – it needs a script. Can anybody help me out?
JohnAndreas Gumm replied 14 years, 4 months ago 4 Members · 11 Replies -
Andreas Gumm
April 25, 2012 at 9:51 pmCould you give us more informations?
Which authoring system are you using?Usually something like your loop track 1 will be defined as menu!
Play button is linked to track 2 which is defined as title.
At the end of playback it links back to the menu!There is no need to script something!
Andreas Gumm
selfemployed media author -
John Dobovan
April 25, 2012 at 11:09 pmSorry, should have been more specific. I’m working in DVDSP3 on a presentation video. There is no menu, just 2 video tracks and 1 subtitle track. First play is set to Track 1, which is just video and audio track 1 and it returns to itself for continuous loop. Track 2 is supposed to be activated by the Play button but I see no way to do that without a script. I have both Title and Menu set to trigger Track 2 (which jumps back to Track 1 after playing).
What I need is a simple script that tells DVDSP to play Track 2 if the Play button is pressed. That’s all. Anybody got an elegant solution?
TIA,
John -
Andreas Gumm
April 26, 2012 at 12:47 amIt will not work the way you want
You can’t assign a specific action to the button you want directly!If the subtitle track is assigned to track 2 you can realize what you want by a simple trick:
– create a title containing track 1
– add a button with 100% transparency over the whole screen size to the full lenght of the video
– assign 100% transparency to all the button states
– make the button pre selected by delfault
– link the button to track 2Since play button on remote control will work like an ENTER button while the disc plays a menu, track 2 will be started after pushing PLAY!
Andreas Gumm
Eric Pautsch
April 26, 2012 at 12:51 amYou wouldnt use scripts but DVDSPs Buttons Over Video function. It’s basically an invisible button covering your entire track. Set this to the other track
John Dobovan
April 26, 2012 at 5:12 pmHmm, yes. That’s my experience as well. Problem is, they want to use the Play button. I can’t seem to find any way to make that happen. Enter causes the track info to display briefly, partially obscuring the start of the video track. Guess I can put a slight delay in the play start. Sure would like to enable to Play button though….
Andreas Gumm
April 26, 2012 at 7:50 pmMany players will start action of the pre-selected button if play button is pushed!
It really depends on the player!Andreas Gumm
Michael Sacci
May 3, 2012 at 7:10 pmBut you cannot (or at least should not) author on what most do.
DVD is a closed spec delivery method you have to play by their rules.
Michael Sacci
May 3, 2012 at 7:13 pmBut you cannot (or at least should not) author on what most do.
