Activity Forums Apple Final Cut Pro Legacy Need recommendation for graphics card for Early ’08 mac pro for FCPX install
  • Need recommendation for graphics card for Early ’08 mac pro for FCPX install
    Posted by Jacqueline Nauman on October 3, 2012 at 6:48 pm
    Is this the right place to post this? I must finally move up from FCP 7 for work. Can’t use FCPX on my system until I upgrade the graphics card. Per the tech requirements from apple I need OpenCL-capable graphics card or Intel HD Graphics 3000 or later. Some research sent me to this OWC link: https://eshop.macsales.com/item/Apple/6615718/ which is more my budget at $269 than the one Apple is recommending at over $879. Can anyone give me some feedback on this and what else I will need before buying the upgrade to X? Thanks in advance!
    MAC: 2 x 2.8 Quad Core Intel Xeon
    Memory: 6GB 800 MHZ DDR2 FB-DIMM
    OS: Mac OS X 10.7.5
    Hard Drive: WDC WD3200AAJS-41VWA0
    Capacity: 319.21 GB (319,213,174,784 bytes)
    Final Cut Pro 7.03
    Neil Patience replied 13 years, 11 months ago 2 Members · 1 Reply
  • Neil Patience
    October 4, 2012 at 4:53 am
    Hi
    I have that 5770 card in an old MACPRO 1.1 and it works perfectly with FCPX. You might want to add a bit more RAM as FCPX is 64 bit and is able to utilise that. Otherwise I dont think there is anything else you really need to get you going.
    best wishes
    Neil
    http://www.patience.tv
