Activity › Forums › Apple Final Cut Pro Legacy › Need QT6
Need QT6
Posted by Bob Vick on October 24, 2005 at 8:02 pmOkay I guess I did update the QT to 7 from 6 pro. Must have done it while I wasn’t looking. Saw the warnings about QT7 and FCP 4.5. So far everything is okay. Should I update to QTPRO or go back to QT 6? If I should go back does anyone have the most recent prior to 7?
bob
Bob Vick sr promo guy @ ch3 wwmt tv, kalamazoo, mi
Jeremy Garchow replied 20 years, 11 months ago 2 Members · 15 Replies -
Jeremy Garchow
October 24, 2005 at 8:09 pmhttps://www.apple.com/support/downloads/quicktime652reinstallerforquicktime701.html
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre -
Bob Vick
October 24, 2005 at 11:20 pmI went there and downloaded the file. But the page does say will remove 7.0.1 and restore to 6.5.2. Will it do the same to 7.0.3?
\b
Bob Vick
October 25, 2005 at 12:12 amThink I will need to input the QTPRO number to get that back?
b
Jeremy Garchow
October 25, 2005 at 12:17 amI would think so, although I don’t know for sure. I imagine when the upgrade took place, it wiped the file that has you QTPro info in it.
Bob Vick
October 25, 2005 at 12:22 amThanks Jeremy. I’ll go for broke here
b
Jeremy Garchow
October 25, 2005 at 12:26 amYeah, there’s no penalty as the upgrade from 6 to 7 has already taken place. You can always reupgrade to 7 with no penalty if the revert back to 6 does not work out for some reason. If I were in your situation, I’d go for broke as well.
For an off topic comment, I had some great times at Kalamazoo College visiting my buddies there. Ahh, the memories.
Bob Vick
October 25, 2005 at 12:32 amNo way! Won’t let me install onto the HD says I cannot install this software on this volume. The disk is dimmed (actually has big red exclamation point) because it doess not contain an appropriate version of QT.
b
Bob Vick
October 25, 2005 at 12:38 amI do have 10.3.9
b
Jeremy Garchow
October 25, 2005 at 12:47 amTry this then run the 6.5.2 reverter.
https://www.apple.com/support/downloads/quicktime701reinstallerforquicktime702.html
