Activity › Forums › Blackmagic Design › need information about Multibridge Extreme
Posted by Zechariah on November 25, 2006 at 1:43 pmHi
I have Decklink Extreme and want to build a new HD system and looking for Multibridge Extreme and have questions about it
1- did it support 2K editing under PPro
2- did 3DBoxx 8300 is suitable workstation for it
3- can I use Apple Cinema HD 23-inch or Dell Ultrasharp 2405FPW for 2Kthanks
Miles Blow replied 19 years, 9 months ago 4 Members · 8 Replies -
Deleted User
November 26, 2006 at 4:09 amHello,
The 2k support is within Adobe Premeire Pro 2 and the Multibridge Extreme as you have projetc settings for this.
I have not used Boxx so I am un-sure if it would be suitable best to contcat Black magic direct.
The 23″-24″ screens would not work, you need a 30″ display to view al the 2k images as stated on Blackmagic’s website.
I bought a Multibridge Extreme great host of inputs, outputs and using DVI is really good for low cost monitoring.
Leo
Zechariah
November 26, 2006 at 9:17 pmHi Lio
thanks for information
in your profile I notices that your system configuration include 4x250GB SATA 1 drives (RAID 0) for storage
did you use it for HD editing “only 4 drives SATA 1” ?waiting for Boxx user with Multibridge Extreme
thanks
Deleted User
November 27, 2006 at 2:55 amHello,
Yes I can use MJPEG or HDV captured via to the SATA 1 drives no problem as the data rate is quite small.
However for uncompressed HD I would need a suitable raid array to cope with the huge data throughput. I am looking into the Caldigit 10 bay drive http://www.caldigit.com these look very good and are good priced.
Thank you,
Leo
Bob Zelin
November 28, 2006 at 1:05 amthe CalDigit will ABSOLUTELY do uncompressed HD. I have just tested it with both AJA and Blackmagic hardware on both a MAC G5 dual 2.7 and MAC Quad.
Bob Zelin
Deleted User
November 28, 2006 at 4:06 amHello Bob,
What type of performance was you getting with the drive? How many streams, what quality, and was it running in protected mode the Caldigit unit or raid zero? I am interested in the s2vr pro the (10 bay drive). I want to work in protected mode with un-compressed 8 bit HD from the JVC HD100U via Component outs and eventually Sony HDCAM on a pilot I want to make.
I am thinking of getting the 5 or 10 drive models. But can’t decide just yet.
Thank you,
Leo
Zechariah
November 28, 2006 at 1:13 pmHi Leo
Thanks for replay,
I looked to CalDigit and I think that you must get (10 bay drive “S2VR Pro 2.5TB”) to get 450MB/s data read for 2K editing as you said that “2k support is within Adobe Premeire Pro 2”but what about CalDigit under Windows XP ?
Hi Bob
Thanks for informationStill waiting for Boxx user
thanks
Bob Zelin
November 28, 2006 at 11:34 pmHi –
this is not a Cal Digit forum, but I will be brief. I checked the 5 drive system, at RAID 0. Protected mode is RAID 1, not RAID 3 or 5, so this is mirroring, which kills half your storage. The 5 drive system writes about 210mb/sec and reads about 230mb/sec, which is fast enough for uncompressed HD. The 10 drive system is obviously much faster because you are creating your raid across more drives, but it will be a lot more money. If you are ok with RAID 1, the 10 drive system will give you the same storage capacity as a RAID 0 5 drive sysetm. Most people want to spend as little as possible, and SATA is incredibly reliable, so most people will stick with the 5 drive S2VR. It’s a great product.bob Zelin
Miles Blow
December 4, 2006 at 11:51 amHey Bob how does it compare to the sonnet fusion 500(i think that was the model you mentioned a while back) That was the one we were thing of going with in raid 0.
