Activity Forums VEGAS Pro Need help with zooming letter effect
  • Need help with zooming letter effect
    Posted by Tonys on August 15, 2005 at 8:16 am
    I am trying to create a motion to a letter. For this example i have used M as a reference, I adding a text to my timline and typed the letter M, setting the font size to 504 and scale to 4.000
    I then added to the begining of that clip a keyframe and followed by adding a keyframe at the end and setting the scale to 0.000.
    This should now look like the letter M is zooming from 504 to 0
    I would like the M to start off the screen as black and then slowly zoom in. Is there anyway to make the letter M larger than 504 or scale 4.000? Or will I need to just add a fade in at the beginning of the clip.
    Edward Troxel replied 21 years, 1 month ago 3 Members · 3 Replies
  • Peter Wright
    August 15, 2005 at 8:29 am
    Try using Pan Crop to zoom in or out.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Tonys
    August 15, 2005 at 11:34 am
    I tried that option but this makes the edge of the letter fuzzy. I cant seem to see any other options in the text editor.
  • Edward Troxel
    August 15, 2005 at 1:28 pm
    Make the letter the LARGEST size. Then use the tools to zoom it OUT. You don’t want to “zoom in” on a SMALL letter. You want to “zoom out” from a LARGE letter – even if you’re zooming in.
    Edward Troxel
    JETDV Scripts
