Activity Forums Apple Final Cut Pro Legacy Need help with my VTR
  • Need help with my VTR
    Posted by Jay Stallworth on December 9, 2005 at 12:26 am
    Hello Cow / calf people,
    I sure could use some help. I am trying to deliver my finished product to my client on Mini DV and DVD. The VTR I am using is not working properly. I can capture from the VTR but it will not recorded any of my finished video. Could any one help me.
    My System:
    Mac DP 1.25 G4
    Final Cut Pro 4.5
    I have a JVC SR-VS30
    Shane Ross replied 20 years, 9 months ago 2 Members · 1 Reply
  • Shane Ross
    December 9, 2005 at 8:14 am
    What happens when you try?
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
    (Who said editing was easy?)
