Activity › Forums › Adobe After Effects Expressions › Need help with .mogrt template that uses csv/spreadsheet files
  • Need help with .mogrt template that uses csv/spreadsheet files
    Posted by Gus Maia on December 18, 2020 at 2:45 am
    Hello, everyone.
    So I’m creating this .mogrt template in AE, that uses a .CSV file to update some names based on the spreadshit.
    Here are some screenshots: https://imgur.com/a/zNa97By
    Everything in AE works great. I change the CSV’s text, save the file and AE instantly updates the names but when I’m using it in Premiere I can’t change any values, either by tipping them on the spreadsheet data window or by importing a new spreadsheet.
    Nothing happens and I believe it’s because the expression I’m using it’s linking to the ‘Bar Chart.csv’ file used in the AE composition.
    Is there any way I can properly call a variable using a expression in AE for it to use a sheet uploaded within Premiere’s Spreadsheet menu?
    Thank you very much for your help!
    View post on imgur.com
    Gus Maia replied 5 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
