Activity Forums Adobe Premiere Pro Need Help With Making Stereo Sound into Mono
  • Need Help With Making Stereo Sound into Mono
    Posted by Gordon Margison on April 19, 2008 at 5:49 am
    I was wondering if anyone would be able to help with this issue I’ve been having. I recorded sound for a film that I am working on with an external microphone, however, this microphone only picks up audio in the left speaker of a stereo setup. When I capture the footage into Premier Pro, it recognizes the sound track as a stereo track and now all of the sound comes solely out of the left speaker. For obvious reasons, I would like to see if there is a way to get this left channel audio to come out of the both speakers – almost like telling Premier that the track is not a stereo track, but a mono one. Any help with this issue would be greatly, greatly appreciated and thank you in advance.
    Brian Kennell replied 18 years, 5 months ago 4 Members · 4 Replies
  • Vince Becquiot
    April 19, 2008 at 4:35 pm
    If you have items in the timeline, use the gill left effect on all clips.
    If you are in a new project, select your footage in the project panel, then go the clip > audio options > Source channel mappings.
    From there you can select the left channel and make it mono as stereo.
    Vince
  • Phocas Kroon
    April 19, 2008 at 8:22 pm
    You can avoid this in the future by making a wire connection in the microphon plug between the connections for left and right.
    Phocas Kroon
  • Gordon Margison
    April 19, 2008 at 9:18 pm
    Thank you so much – that solved the problem! Phew – I was getting pretty worried there for a moment!
  • Brian Kennell
    April 22, 2008 at 3:26 pm
    To have Premiere break a stereo audio clip into dual mono clips: Select the audio clip in your project window, go to Clip->Audio Options->Breakout to Mono.
    This splits the stereo clip into two mono clips inside your project. From there you can use whichever channel you want.
