Activity › Forums › Apple Final Cut Pro Legacy › Need help with FCP component video setting
  • Need help with FCP component video setting
    Posted by Riclbs on October 9, 2007 at 2:19 pm
    Hi everyone,
    I am attempting to capture footage from a Sony DSR 80 using component inputs. I had the A/V settings in FCP a couple of weeks ago but forgot to create an Easy Setup for it and now I can’t remember the settings I made. Could someone please provide me with the settings for such a setup? Many thanks.
    Riclbs replied 18 years, 11 months ago 2 Members · 2 Replies
  • Rafael Amador
    October 10, 2007 at 2:16 am
    Sony DSR 80 is DVCam so is just DV. You need to set your capture preset DV PAL or DV NTSC and select Annamorphic or not , depending of how you have shoot.
    Just capture through Firewire. You won’t get any bennefit by capturing components.
    Cheers,
    rafael
  • Riclbs
    October 10, 2007 at 2:23 am
    Thank you, friend. As it turns out someone had switched some of the cables around without my knowing it, so once I got that fixed, I was able to get it back. Oh well. . . . .
