Activity Forums Adobe After Effects Expressions need help with expression :)
  • need help with expression :)
    Posted by Alek Panfilov on October 17, 2005 at 4:55 pm
    hi all ,
    got some problem with expression , i’m not so good with math so maybe it’s very simple but i just can’t generate it with my brain 😛
    i need an expression that will generate randomly values 0 or 100.
    please help 🙂
    Alek Panfilov replied 20 years, 11 months ago 2 Members · 3 Replies
  • Dan Ebberts
    October 17, 2005 at 6:55 pm
    If you want it to change as fast as possible try this:
    Math.round(random())*100;
    If you want to slow it down try this (and adjust freq as necessary):
    freq = 5;
    if (wiggle(freq,10) < value) 0 else 100 Dan
  • Alek Panfilov
    October 18, 2005 at 10:29 am
    thank you Dan , it helped me out 🙂
  • Alek Panfilov
    October 18, 2005 at 10:53 am
    once again i have a Q about expressions,
    firt of all, in comp i have a slider wich is generating random numbers between 0 and 100 ,
    and also i have 8 solids, attached to objects in zaxwerks inv, and i want Z-3d-scale values of
    those solids to act like equalizer led, so i was thinking about expression for the Z-3d-scale
    of those solids wich will look something like this :
    temp = thisComp.layer(“slider”).effect(“Slider Control”)(“Slider”);
    temp2 = if(temp //HERE I DONT KNOW WHAT TO ENTER// = array (20, 100))100 else 0
    [100, 100, temp2]
    and now explanation to my heretical writings 😛
    i whant temp2 to be 100 when temp is in array between 20 and 100, when its below 20, temp2 is 0.
    i’m little lost in expression , so maybe it’s not properly wrighted, but way of thinking is good 😉
    cheers.
