Activity › Forums › Apple Final Cut Pro Legacy › Need help with darkening one side of the frame
Posted by Tobias Schrenk on April 6, 2009 at 8:20 pmHello,
because of some time problems we have a big problem in one of the last scenes of a short movie. The main actress is on the left side of the frame and you can see the right section of the room.
The right side is already a little bit darker than the part of the actress but some folks thought the are out of frame and walking around. It was the last shoot on a one day shooting so at the end no one noticed it.
Here is my question. Is there a way to darken the right side of the fram on a way that it looks some kind of nice and you can´t see the people ?
I am really thankful for any help.
Thanks a lot
Tobias Schrenk replied 17 years, 5 months ago 4 Members · 9 Replies -
John Fishback
April 6, 2009 at 8:27 pmHow about zooming up the frame and repositioning the bad side off the screen. Double-click the clip and in the Motion Tab in the Viewer increase the scale. Then in the canvas select Image + Wireframe. That allows you to move the image around in the Canvas.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Tobias Schrenk
April 6, 2009 at 8:45 pmI thought of this but I can´t zoom into the frame that much. It works a little bit but still you can see too much of the background
First Last
April 6, 2009 at 9:05 pmHow about masking out the parts you don’t want with something like After Effects?
Production Associate
Bend, Oregon, United States -
John Fishback
April 6, 2009 at 9:15 pmYou could use Photoshop to make a gradient matte. Have it go from black on the right to white on the left. Put that on a video track above the problem clip and set the Composite Mode to multiply.
John
Ed Dooley
April 6, 2009 at 9:32 pmI use Joe’s Filters’ Soft Gradient, but you can build your own to suit.
Edhttps://www.joesfilters.com/joes_soft_gradients
John Fishback
April 6, 2009 at 9:41 pmIn FCP in the Effects Tab > Generators > Render there’s a gradient generator. Works fine. Just tried it. Never knew it was there.
John
Tobias Schrenk
April 6, 2009 at 10:01 pmJust tried the gradients but it doesn´t work for me. Never worked with them. Could you explain me in a few words what I have to do with the Gardient generator ?
John Fishback
April 6, 2009 at 10:12 pmDrag the gradient generator to the track above the clip you need to fix. Change the Composite Mode (rt-click or ctrl-click to choose Composite Mode) of the generator to Multiply. Now you should see the two frames blended together in your monitor and the Canvas. If you need to move where the black is in the frame, set the Canvas to Image + Wireframe (3rd button to the right on the top edge of the Canvas window). Then with the generator track highlighted (selected) you can click and drag in the Canvas to position the gradient.
John
