Activity Forums Apple Final Cut Pro Legacy Need help with compression settings for AppleTV
  • Need help with compression settings for AppleTV
    Posted by Matthew London on April 2, 2008 at 5:12 am
    I am trying to put my feature film onto AppleTV for use as a distribution device to send to movie theatres that dont have Digibeta decks. Source is 10bit Uncompressed Anamorphic, in both PAL and NTSC versions. I want to put both on the AppleTV.
    In the included preset for AppleTV (using Compressor 3.0.2 with all the latest software updates), the only choices I see are for AppleTV HD and AppleTV SD.
    My source material is NOT HD. Should I choose the HD version anyway and have it upconvert? I’m not in front of Compressor right not, but the SD option was a lower resolution than my PAL or NTSC source material, so that doesnt seem like a good option.
    Is there any way to compress to the the native resolution of the PAL (720×576-Anamorphic) or NTSC (720×480-Anamorphic)? Would these even play out properly on the AppleTV?
    Basically want the highest quality output going out to the HD capable projector.
    Many thanks…
    Matthew London replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
