Activity Forums Zaxwerks Need Help with Camera Movement
  • Need Help with Camera Movement
    Posted by Alan Dubov on May 25, 2008 at 12:18 am
    I have made a 3d world in AE using various clips and I have the camera movements moving in and around this world. I want to put in some objects I made in Illustrator. Here is the problem: When I put in the objects and select the “use comp camera” in Invigorator, the objects become very small and are way off the position I put them in. Is there a way to position the objects and then use the AE camera for the movements?
    Jon Okerstrom replied 18 years, 4 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    May 28, 2008 at 3:12 am
    Hi Alan,
    You can choose “use comp camera” for many projects and it works fine. You can adjust the lens setting of the comp camera if you need to.
    Having said that, there will be cases when it won’t work… depending on the camera movement and what else is going on in your scene.
    Jon
