Activity Forums Apple OS X Need help using ichat to remote control imac
  • Need help using ichat to remote control imac
    Posted by Larry Watts on November 1, 2008 at 2:26 am
    I’m trying to help my 84 year old dad. I’ve used ichat to create a remote session taking over his computer so I can see what problems he has , fix things and install software, but it is sporadic whether I can get on or not.
    He has cataracts so he can’t always see what I’m talking about.
    Is there a way so I can log on without him doing anything to set up the session, including opening ichat?
    Larry
    John Davidson replied 17 years, 10 months ago 4 Members · 3 Replies
  • Curtis Thompson
    November 1, 2008 at 2:54 am
    hello…
    you could put it in the startup items to open it every time the box started – not sure if it has an auto-login feature, but i bet it does…that would do it…
    fancier than that you could use a unix cron job to check to see if it’s open every X minutes and re-open it if not, but the above would be a good start i’d think…
    sitruc
  • Zane Barker
    November 1, 2008 at 7:58 am
    [Larry Watts] “Is there a way so I can log on without him doing anything to set up the session, including opening ichat? “
    Set ichat to automatically launch on start up, then you will need to set up this auto accept for screen sharing.
    https://www.getstonered.com/2007/11/applescript-automatically-accept-ichat.html
    I have not tried it, so I cannot say how well it works.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • John Davidson
    November 2, 2008 at 7:18 pm
    I believe I used that same script before and it works. We left our dog for a few days (people were staying with her at night) and initiated video chats with her from hawaii. The macbook was put in the room and left on. We had to adjust power management so that the display would sleep but that the computer wouldn’t shut off. It worked.
    Another, simpler option would be to go under ichat prefs. Switch to the ‘video invitation’ event, and then check the ‘run applescript’ box. highlight ‘auto accept’, and he’s good to go. The only issue could be if he gets alot of video invites, but at 84 I’m guessing you’re probably the only person on his buddy list :-).
    In your situation, you might want to also use the same mobile me account so that you can start screen sharing via back to my mac. If his internet goes down, aol IM service is interrupted, etc., ichat will log off and cause problems.
    The section about having ichat automatically come on at startup is an excellent one as well. Just be sure you teach him how to restart and that he gets that down pat. After that you should be able to overcome any difficulties you encounter.
    Good luck!
    John
    Magic Feather Inc.
