Activity Forums Adobe Premiere Pro Need help setting up project?
  • Need help setting up project?
    Posted by Sean Tatalovich on September 28, 2007 at 10:08 pm
    I am putting together a project of newsclips from TV but there quality is already pretty low. Footage I have isn’t the greatest.
    This will be viewed on desktop only but I am worried about quality.
    I chose in project custom > desktop and the rendering quality was raduim which is bad right?
    Mike Velte replied 18 years, 12 months ago 3 Members · 7 Replies
  • 7 Replies
  • Sam In leeds
    September 28, 2007 at 11:50 pm
    What format is your footage in, and how was it captured? This will help determine which preset is best for you.
  • Sean Tatalovich
    September 29, 2007 at 12:26 am
    It was originally Beta but has already been turned into low low quality QT movies.
  • Sam In leeds
    September 29, 2007 at 12:57 am
    What resolution have they been converted to?
  • Sean Tatalovich
    September 29, 2007 at 8:22 am
    there like 640×480. 20MB. Bad quality.
  • Mike Velte
    September 29, 2007 at 9:38 am
    If you just need to make cuts with no effects or titles, QT Pro can do the cuts and stitch pieces together WITHOUT re-rendering. Re-rendering will cause another generational loss of quality.
    Otherwise create a custom project with the same resolution as the source and edit in Premiere.
  • Sean Tatalovich
    September 29, 2007 at 7:51 pm
    I have already done alot of work on it. When I go to Project REndering settings there at Cinepak. Other options it gives me is:
    Microsoft Video 1
    Micrsoft RLE
    Uncompressed UYYY422 8bit
    None
    Should I use none? Since it will be compressed in end?
  • Mike Velte
    September 30, 2007 at 9:39 am
    Choose File>Export>Adobe Media Encoder
    Format= Windows Media
    Preset= NTSC Source to Download 512 Kbps
