Activity Forums Adobe After Effects need help “rewiring” a text animation preset
  • need help “rewiring” a text animation preset
    Posted by Terry Coolidge on December 21, 2006 at 8:35 pm
    I have been using the “Word Processor” text animation preset for some title sequences I have been working on, and I have discovered that I would like to be able to use the effect “in reverse” so to speak. I want to have it function exactly as the preset except that I want to have it type out a line of text from right to left. So I would want the “cusor” offset to the left (instead of to the right) so that it leads a text string as it is revealved from right to left. I have taken a stab at changing the various properties and settings to achieve this result, but I can only get portions of it looking correct. I definitely need help from someone who has a better understanding of text animation “selectors” and such.
    Mylenium replied 19 years, 9 months ago 3 Members · 3 Replies
  • Mylenium
    December 22, 2006 at 7:39 am
    You have to revert the timing by subtracting the offset values from the overall text length like 120-effect(“Type_on”)(1)
    Mylenium
    [Pour Myl
  • Julian Sixx
    December 22, 2006 at 11:33 am
    Hi
    [Mylenium] “You have to revert the timing by subtracting the offset values from the overall text length like 120-effect(“Type_on”)(1)”
    In order to get the length of the text i tried this expression.
    L=text.sourceText.length
    L-effect(“Type_on”)(1)
    But it doesn’t work.Now the text just fades from right to left.Is it that what you mean Mylenium?
  • Mylenium
    December 22, 2006 at 5:30 pm
    When I tried this morning, it worked, but I used fixed values. But you may be right. It’s possible that the cursor does not react to this and I overlooked it.
    Mylenium
    [Pour Myl
