Well, depends how close after the event you need your stuff. If you mean like giving things to people as they leave the building after an event, then your options are limited and it actually most likely boils down for you to have to switch to a dedicated hardware/ software combo that very much functions like a broadcast system with realtime transcoding. Certain flavors of NewTek’s VideoToaster do this for instance. The big part is getting MPEG-II video. Once you have that, using Encore would not be a problem, assuming you are working on a reasonably fast system and the import goes at reasonable speed. If even that’s not enough, you’ll have to look into commercial archiving systems for TV stations and media agencies, but those cost real big bucks.
Mylenium
[Pour Myl
