Activity Forums Apple Final Cut Pro Legacy need help quick, shots I cut out are showing up in exported movie
  • need help quick, shots I cut out are showing up in exported movie
    Posted by Andrew Kastner on November 16, 2009 at 5:22 am
    I have been working round the clock to finish an important piece by tomorrow. I am now done but the exported version has shots that I cut out and arent even in the tikmeline anymore. I replaced them. THe capture scratch that had the shot is there but since I used the splice tool and dleted the unwanted shots, how can they stil be there after I export. I NEED SERIOUS HELP QUICK. I am using final cut express latest veruion in a macbook pro. Thanks
    Andrew
    Anthony Moreschi replied 16 years, 9 months ago 2 Members · 1 Reply
  • Anthony Moreschi
    November 16, 2009 at 3:55 pm
    Try trashing your prefs and restarting the entire system. Then just export a portion of the timeline that was giving you problems to see if that worked. If that doesn’t work, try using the media manager to create a project that only has the media that is being used.
